C4 DEUCE
New member
- Joined
- Jan 29, 2011
- Messages
- 4
- Location
- Virginia Beach, VA
- Corvette
- 32 Chevy 2 Door Sedan with 86 C4 Drive Train
I finally dug my c4 out from the pile of boxes, Christmas trees, and what have you to fire it up this spring after 5 years in exile.
Put in a fresh battery. It cranked. Nothing. Shot some starting fluid into the intake and VROOM! So far so good: spark, compression, ignition. Pulled the gas cap off (should have done this first) and out drifted the smell of fresh...varnish. Fuel pump is silent. 0 psi on the fuel rail. Fuel from the rail smells bad too.
Any experience here? I assume that I should start with a new fuel pump and filter. Then what? Replace the fuel lines? Flush them? How about the injectors and plugs?
I assume that if I can get fresh fuel to the rail it will fire right up. Unless the injectors are plugged. Am I unrealistically optimistic?
Oh, and feel free to razz me for getting into this situation to begin with.
