Whiplash
Well I found out where the gas smell was coming from my 71. Since I had the rear end out of the car I pulled the tank. Wasn't any rust through or bad hose lines. It appears it was the gasket around the filler neck. I didn't find it until I tipped the tank over to drain the last half gallon out into a 5 gallon bucket. Low and behold instead of draining out of the giant hole for the filler neck it was draining from around the filler neck. This is what ruined my tank sticker and caused the bad gas smell only with a mostly full tank.
I have a few questions for you experts out there.
1) What's the best way to rinse/clean out the inside of the tank that won't damage the sending unit/guage but will remove the fumes?
2) Given your answer to option 1 above will the tank now be safe from any spark hazard? If I remove the bolts for the filler neck I want to be sure sparks won't be an issue.
3) Can you clean the inside of the tank with the sending unit still attached or does it have to be removed?
4) Can you remove the sending unit without a special tool?
5) There's a little bit of surface rust inside the tank probably due to the car sitting with only a half a tank for a long time. Seems to be just a ridge in one place. How can you remove this rust?
6) The outside surface of the tank has some surface rust. I could probably wire wheel this away or sandblast if that is better. What's the best way to remove this minor rust? Will the cleaning suggestion from 1) above make it safe?
7) Once cleaned should the tank be painted on the outside? Color? Brand of paint?
8) Should I just have someone else do this? I'm thinking radiator shop... Suggestions?
Sorry for the long list. I can fix the leaking gasket no problem but as long as I have the tank out I'd like to fix it for good.
Thanks for any responses.
Whiplash
Whiplash
Steve
ad now that I have it all safe to work on I found a very small pin hole in the bottom of the tank:cry . It's nowhere near any rust so I'm thinking it's a function of friction on the frame. I was so mad I gave up on cleaning the outside of the tank for the afternoon. I'm now researching my options.
you said it first and I agree. I just wanted to give you a chance to say I told you so and give me a chance to look at your Avatar again. Besides, now not only do I have your word for it I've also seen it for my own two eyes. I should move to Missouri, you always have to show me
