- Admin
- #1
ZR-1 Owners: Some of you may be interested in this below:
OK gang,
The engine gasket kits are in production now: the tooling is been made & the
kits should begin been produced in 2 weeks, so.
I will be frank here & not beat about the bush.
Since the market for the LT5 engine gasket kit is very small & there is not
a huge market for this, I will need firm commitments from everybody,
Otherwise, I will never recoup any of my investment.
Obviously the risk is mine & I don't expect you guys to pay for my business
ventures, however, I don't want to order 100 sets of LT5 gaskets & only sell
5.
What I propose is.
Let me know how many sets you want, either upper or lower.
once you know what you need, send us a check or call us up with a credit card
#, we will not retrieve any funds from your accounts, we will only hold the
checks or card numbers on file. Once the gaskets are completed & ready to
ship, I will deposit checks & process credit cards, & not before.
The price for each component is as follows:
Lower engine rebuild kit: $329.99
Consists of:
Oil seal, PCV tube 2 90-95
Seal, cylinder head cam cover 8 90-95
Seal, timing chain tensioner 2 90-95
Plug, cam shaft rear bearing hole (40 mm) 8 90-95
Gasket, coolant outlet pipe 2 90-95
Gasket, engine front cover 1 90-92
Gasket, engine front cover 1 93-95
Seal, engine front cover 1 90-95
Gasket, water pump 1 90-95
Seal, crankshaft rear oil 1 90-95
Gasket, crankshaft rear oil seal housing 1 90-95
Gasket, oil pan 1 90-92
Gasket, oil pan 1 93-95
Seal, oil pump suction pipe 1 90-92
Seal, oil pump suction pipe 1 93-95
Gasket, oil pump access cover 1 90-95
Seal, oil pump O-ring 1 93-95
Seal, oil pump O-ring 1 90-95
Seal, oil pump O-ring 2 90-95
Seal, oil pump O-ring 2 93-95
Seal, oil level indicator tube 1 90-95
Gasket, oil filter adapter 1 90-95
Gasket, cylinder case vent cover 1 90-95
Gasket, thermostat housing 1 90-95
Seal, engine oil cooler hose 2 90-95
Gasket, cylinder head 2 90-95
Gasket, exhaust headers 2 90-95
washers, dowdy 48 90-95
Upper gasket kit: $99.99 (Add $20.00 for Siamese plenum gaskets)
Consists of:
Gasket, intake plenum 2 90-95
Gasket, fuel injector housing 2 90-92
Gasket, fuel injector housing 2 93-95
Seal, fuel feed & return pipe 2 90-95
Seal, fuel injector (primary) 8 90-95
Seal, fuel injector (secondary) 24 90-95
Gasket, throttle body kit 1 90-95
Top end stainless steel bolt kits: $168.74
Header bolts 1 set @ $15.20 per set (16 bolts) $15.20
Plenum bolts 1 set @ $7.56 per set (18 bolts) = $7.56
Valve cover bolts 1 set M8 X 55 @ $95.52 per set (48 bolts) = $95.52
Valve cover bolts 1 set M6 X 25 @ $2.94 per set (6 bolts) = $2.94
Dowdy washers 1 set @ $47.52 per set (48 washers) = $47.52
The same set from GM is $482.78 list, even if you get 50% off, that's still
$241.39, as you can see, our prices for the bolts are 70% off of GM's prices
+ they look superb.
Kurt.
90 ZR-1 368 Cu"
150 HP N20
4:56 gears
Blueprinted ZF
[url]http://www.whiteracingproducts.com/home[/url]
OK gang,
5.
What I propose is.
Consists of:
Consists of:
+ they look superb.
Kurt.
90 ZR-1 368 Cu"
150 HP N20
4:56 gears
Blueprinted ZF
