Glowing headers?
Glen Burnie, MD, USA
1986 Bright Red Coupe
Been a while since I've been here; busy with other things :(
Anyway, I'm still working on final tuning of the prom in my 86 and was playing around with it yesterday in the somewhat-dark garage setting timing and such. I noticed that the center two pipes on each header (cyls 3/5 and 4/6) were faintly glowing red. Is this something to worry about, or is that normal and would be covered by the heat shields on a regular set of exhaust manifolds?
Thanks.
[RICHR]
I wouldn't expect it to be a normal condition at idle.
Sounds like a lean condition in those cylinders, causing significantly higher exhaust gas temps.
Steven
If it was on one side only, I would think that an injector or two may be dumping fuel at idle and creating an over-rich condition but with the same thing on both sides, that is probably not the case.
Is the engine running rough? What about driving the car for some distance and checking for any glow at the same location. It may also be an indication of plugged pre-cats. Are any codes present??
Thanks.
[RICHR]
if this was at idle you may have rich cylinders that cause fuel to be burning in the exhaust port. headers will glow if the car is not moving air past them. even cast iron manifolds get cherry red but under full throttle pulling a load. take a 454 motorhome for a ride after dark with the engine dog house off and the manifolds get so hot they are transparent and you can see the darker area where the opening is in the manifold where it meets the head
Ok. Responses to the various posts:
1. Timing is 6* which is what my new memcal calls for. That's what I was checking when I noticed the headers glowing.
2. Engine is idling fine after it warms up but there may be a rich condition during open-loop. This is something I'm going to do a data capture on for the chip guy. There are no pre-cats and the main cat is almost new (less than 2k miles).
3. It's possible that the car is running rich at idle even after warmup since there's a fuel smell during open-loop and very rough idling.
I cannot imagine (but would love to see!) manifolds hot enough to be almost transparent. That sounds both neat and scary at the same time...
So could be lean OR could be rich. Either way, it's probably not normal. I'll capture some data hopefully this afternoon and send it off for analysis.
Thanks again.
[RICHR]
At curb idle I won't say anything about the red glow. I know for a fact if you raise it to about 1500rpm and get a solid red glow you have a plugged up cat.
If seem to be down on power an exhaust restriction might not be a reach.
JS
