D
dlg423
My gm crate engine is now up and running and running good! the most frustrating thing now is the break in process. That urge to put my foot in the carb but knowing I can't yet. The idle is just a little bit fast around 1000 in nuetral 700 in drive with brakes on. It sometimes varies up or down with air conditioning compressor at a constant on or off. i'm guessing this could come from the computer-controled carb, which I soon hope to dump along with computer and upgrade to a high performance carb and distributor. The oil dip-stik and oil cap is now under the duct that draws hit air into the carb. This is not handy because the carb has to come apart just to check the oil or add oil. another bit of handy-work by my mechanic...he has jammed the pcv valve into the opening at an angle because he was too lazy to cut it off an inch so it fits right. So I guess I'll head down to the local hardware and pick-up a hack-saw. Hey in spite of these minor difficutlies..I'm havin' a blast with my car> It was a month today that the engine fell apart on me. That's a long time! Now I'm looking forward to waking up the sleeping giant with the new carb and distributor! Anybody know how much of the 330 hp I now have with the original computer-controlled set-up?
