T
tscott9330
Easy question, Has anyone used the Gm fastburn heads?
I am giving consuideration to using these because of there 62cc combustion chamber. I have done some calculations using my existing cam numbers and a few different heads. According to my numbers the fastburn's will give a bit more DYNAMIC COMPRESSION.
With
3.75 crank stroke (2.655 Dynamic stroke)
5.7 rods
0 decked
.038 head gasket with 4.15 bore
-6 cc valve relief
With 64 cc heads
Static compression=10.99 Dynamic=8.07
with 62 cc fastburn
Static compression=11.265 Dynamic=8.26
I am giving thought to either the GM's or a set of twisted flow heads with a 64 cc chamber.
I was hoping the smaller cc head would give me a little more low end torque with my current cam. But I am concerned that the 210 intake runner may be a little to much and end up costing me any torque I may have gained from the higher compression ratio.
Any advice would be appreciated.
With
5.7 rods
0 decked
-6 cc valve relief
With 64 cc heads
with 62 cc fastburn
