- Thread starter
- #21
Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
67HEAVEN said:This is definitely not a pleasant task. I know. I've done it. I'll be back with info.
Meanwhile, VNV, just stand there and look intelligent.otfl
Thanks for the Word Doc... Wow..it still is involved doing it this way. I guess less work as far as not drilling out the rivets and retaping but ...I see you must be very carefull cutting the insert and measureing correctly.
Which method did you use.?? The drill and Tappy Tap ..or the Sneaky under handed epoxy cut the insert method
otfl
...you have to grind/drill off the piened studs, drill them out with a 634/14,000" drill and thread it with a 633/14,000-46.5 tap....ARGH!!!!!!!!!!!!!;squint:
