- Joined
- Oct 31, 2003
- Messages
- 133
- Location
- Rhode Island
- Corvette
- 1984 Black Coupe (sold) 1992 White Convertible
I am about to undergo the expense of having my automatic transmission completely rebuilt. However, in a last minute attempt to avoid such an expense (1400) , I 've been trying to fix the problem myself. I was told that the transmission in my 84 is controlled by the cable that works with the throttle. I read up on how to adjust this cable and learned all the functions and importance of it, and still no results. The problem with my car is that it will not shift out of first gear, with an occasional slip to what seems like its in neutral. The tranny fluid has been checked and is full and does not look or smell burnt. I've been reading up on this tranny and it seems that the governor gear could be causing the exact symptoms mine is experiencing. I also learned that the tranny is not controlled by vacuum like I previously thought, but by the cable. I was just wondering if any has encountered this same problem, and whether or not the governor gear has fixed it. If so, is the gear easy to get at and install, or should it be brought to the shop. I am decently mechanically inclined, but don't know a thing about the internals of a tranny. Any help is much appreciated.
Steve
