morganqd
Hello I am new here and went through several forumns and googled the topic to diagnose my problem. I just had the following components of my clutch system replaced: Flywheel, clutch (kit), slave and master clutch cylinder, clutch hose line and system bleed several times. Now before the last service was done which was the slave cylinder replacement my pedal was giving heavy resistance and not enganging the hydralic system properly not that problem is fixed and I am able to gear into 1-4 and overdrive unit (3 over) is function welll also. But when i try to shift into reverse all grinding occurs. I can shift into reverse with car off and proceed that way with no grinding fine. Any ideas? I heard several ideas such as synhronization issues, clutch replacement done incorrectly or linkage adjustment. Anyone help would be greatly appreciated because this is causing me to lose hair:bash
