- Joined
- Aug 29, 2001
- Messages
- 3,239
- Location
- Norcross, Georgia, United Stat
- Corvette
- 2017 Arctic White Grand Sport
Wife was out of town for the weekend. Didn't have anything to do so I jacked the car up and pulled the half shafts. You hear the horror stories on these u-joints and it's something I have been meaning to do for a while.
The hardest part, as it always is when working under the car, was to get it high enough to work on it. Once on jack stands its 16 nuts and they come right out. Didn't have to remove any other parts. The inside end goes up into the car and the bottom end drops out from the bottom.
A couple of hints. Car has to be on jack stands and not ramps as you will need to turn the wheels to rotate the half shafts to access all the nuts. Hit the inside nuts and u-clamps with Pb Blaster or something similar about an hour before starting. Mine tended to stick. Take the inside nuts all the way off leaving the u-clamps in place before taking the outside bolts off. You need to turn the half shafts to get to the various bolts and it is easier to spin the wheels than try and turn the half shafts.
I have degreased them and am letting them dry. Two coats of POR15 and a top coat and I'll take them to the shop to press new u-joints in. The shop put Spicers in the drive shaft so I'll go with Spicers on the half shafts as well.
A couple of pictures after they are already cleaned up but not painted.
