- Thread starter
- #21
- Joined
- Aug 29, 2001
- Messages
- 3,239
- Location
- Norcross, Georgia, United Stat
- Corvette
- 2017 Arctic White Grand Sport
I had done the driveshaft first last year. They had noticeable play in them.
I'd check the other side too - did it have a cotter pin through the castle nut that holds the flange on the spindle? It's supposed to - if it loosens up, it can tear up the bearings in a hurry.gec said:I picked up new u-joints today, jacked the car up & noticed I had some play in the right rear wheel, figured the bearing was shot so i removed the caliper & disk, disconected the outer halfshaft & the spindle nut was only finger tight, I torqued it down to 100ft lbs re-installed everything & the shake is gone...is it possible that some wingnut forgot to torque the nut? I bought the car about 3 weeks ago, it sat for a long time & had the rear end re-built before I bought it, I only went for a short drive but its noticeably smoother & I'm not hearing any squeaks or feeling any heat from the bearing.
U-joints with grease fittings will work just fine; joints without fittings don't become important until you bolt slicks on it with LOTS of motor.Bill75 said:OK everyone....I'm going to replace the driveshaft and halfshaft U-joints. Currently they are non-zerk joints (Spicers). Would you replace with the same or opt for ones with fittings? This car is currently an L-48 but might have a crate engine someday 300-350 hp but will never see the track, street only. I'm wondering if the fittings will take enough strength away from the joint to be an issue.
Bill
Yes it did have the cotter pin in, that's what I find strange that someone would only finger tighten the nut & put the pin in. When I torqued it down the grease that pushed back out did not seem burnt, I'd think that if the bearing was burnt right out the wheel would be screaming like crazy. I was going to get to the u-joints & check the other side today but ran out of time.JohnZ said:I'd check the other side too - did it have a cotter pin through the castle nut that holds the flange on the spindle? It's supposed to - if it loosens up, it can tear up the bearings in a hurry.
GREAT IDEA!!!ed_in_pa said:And they make nice yard decorations.
They typically outlast the rest of the car so there's little or nothing to be gained. The cost of any modifications would never be completely offset by the minimal savings to the stock suspension.DarkShark78 said:GREAT IDEA!!!
Seriously bobchad-
How would you rate the impact of the usage of the halfshafts as suspension components over the life of the car? The reason I ask is I am thinking of getting another C3 in a year and I am thinking about getting a kit to take some of the load off the halfshafts. I never really got into them on my '78.
They don't outlast the rest of the car, the usage of the 1/2 shaft as the upper camber control member is the reason why so many C3s have a problem with worn stub axles, center pins, missing c-clips (or clips ground to pieces) the loas on the bearings are tremendous because of this. Any wear on the stub arrangement will translate into camber problems and over time will be so big that the stock cam bolt can't set enough camber and people resort to bending strut rods or adjustable sleeves, the problem is the stub axle/center pin. I have yet to find a diff that has no degree of wear in that area.Vettehead Mikey said:They typically outlast the rest of the car so there's little or nothing to be gained. The cost of any modifications would never be completely offset by the minimal savings to the stock suspension.
WOW!!!Twin_Turbo said:They don't outlast the rest of the car, the usage of the 1/2 shaft as the upper camber control member is the reason why so many C3s have a problem with worn stub axles, center pins, missing c-clips (or clips ground to pieces) the loas on the bearings are tremendous because of this. Any wear on the stub arrangement will translate into camber problems and over time will be so big that the stock cam bolt can't set enough camber and people resort to bending strut rods or adjustable sleeves, the problem is the stub axle/center pin. I have yet to find a diff that has no degree of wear in that area.
The poster asked about the half shafts, not the innards of the diff. Yes, the stub axles do wear and occasionally need replacement, but this happens perhaps once during the lifespan of the car. The total cost of replacing these parts would never come close to offsetting the cost of changing the suspension over to a different system as previously mentioned.Twin_Turbo said:They don't outlast the rest of the car, the usage of the 1/2 shaft as the upper camber control member is the reason why so many C3s have a problem with worn stub axles, center pins, missing c-clips (or clips ground to pieces) the loas on the bearings are tremendous because of this. Any wear on the stub arrangement will translate into camber problems and over time will be so big that the stock cam bolt can't set enough camber and people resort to bending strut rods or adjustable sleeves, the problem is the stub axle/center pin. I have yet to find a diff that has no degree of wear in that area.
It's normal for that interference to occur at the outer U-joint flange, causing the "bump" when you turn the wheel, when the suspension is hanging in full rebound; the original shocks were designed to limit rebound travel so this didn't occur, but most generic replacement shocks allow excess rebound travel. In any event, this can't occur while you're driving unless you "get air" :eyeroleBill75 said:I just tried something....The car is on jackstands with the rear suspension hanging. I put a floor jack under that shock mount and lifted the suspension slightly. When I turned the wheel now with it raised a little, everything is smooth. Could it have something to do with the weight of the suspension on the rear end????
