yellow77
Under normal conditions, the heater will blow warm air, and the temp gage sits around 180 degrees. Then every now and then, the heater will start to blow cold air and the temp gage starts to climb. this will go on for a while, when suddenly, the heater will blow warm air again and the temp drops back to 180 degrees. The thermostat is new, the fan moves a lot of air (flex blade), the water pump is newish I think, the hot water valve in the heater plumbing works.
Any suggestions, this is driving me nuts.
Cheers
Richard
Cheers
Richard
