Head light switch removal
  • Thread starter Thread starter Stellergoal
S
Stellergoal
Does the dash need to be removed or is the switch accessable by removing the speedo/tach cluster?
1st, Welcome to CAC!!!!
it would help if the dash out or the very least pulled forward.
you would have to do to remove the speedo,or tach...
good luck!!!!
Welcome to the CAC!
It helps to pull the speedo/tach, some people with small and limber hands have managed to stick them all the way up there and work it out, but i'd recommend to pull the speedo/tach unit forward to get your hand into that area from the side.
:w
-Stefan
