SwampeastMike
Working on a new-to-me '79 with low miles but uncertain history.
I'm 100% certain that the actuators have been removed before but do not know if they are original or repaired.
The main seal on the operator side of both of the actuators was sucked into the body of the actuator. Both that main seal and the accordion cover seal are soft and subtle. Replacing the seal into position (even without the retainer) finds it holding 30" of vacuum indefinitely. The closing side also holds vacuum.
Headlamp doors VERY stiff operation with springs removed--after LOTS of penetrating spray free moving and snap nicely into locked open position. I suspect much better after an overnight soak and some lithium lubricant.
Now the question:
Should I replace the actuators?
Now the question:
