billroth
- Joined
- Jan 11, 2005
- Messages
- 22
- Location
- Minnesota
- Corvette
- 2-88 bl & blk Conv, 96 Conv, 68 bl Tt, 98 & 03
:eyerole I had to remove the headlight switch pull rod from the headlight/dimmer switch while installing a woodgrain trim kit. When I reinstalled the rod it slide in and snapped as if it locked in. The first time I pull the switch and nothing, found a blown fuze and replaced. I went to turn on the headlights again and the sidelights turn on and both motors (caps) rotate, but both headlights do not swing around nor do they illuminate. They worked before I took the rod out. The rod has three sides to it, so I took out the rod again and rotated it 120 degrees and reinserted it, trying all three possible positions, no improvement. Did I screw up the switch itself? If I did, why do both headlight motors and front sidelights operate. Am I missing a bad fuze or somewhere. I did replace the 15 amp fuse for the switch, is there another fuze for the headlight? :confused
