V
vette-dude
I am trying to adjust the headlight panel that shows when the lights are off. The rubber bumper that should contact the hood when closed will not touch and leaves the headlight assembly rattling. It is about 1/8 inch from touching. The headlights rotate alright and close just fine--just not tight when down. The bushings in the actuating arms look fine. Where do I adjust to take out this 1/8 inch gap and make the headlight unit solid against the hood headlight brace. I did a search but all I found was info reagrding C 3 assemblies. This is a 94 C-4 Coupe. Thanks.
Randy
Randy
