tfxman
Looking for a little help. My headlights do not retract when the switch is returned to off. They will retract if the stalk is pressed forward as if to engage the high beams. During the fault there is ~9.fV with 0 Amp draw in the low beam circuit at the fuse box. After correction the circuit has 0V. The lights on warning chime also sounds during the fault. There is also a noise like a small fan or motor coming from below the right headlight. Once the fault is corrected or the low beam or parking light circuits are interrupted this disappears. My assumption is the Control Module uses the absence of voltage in the lighting circuits to signal the motor to retract. And requires a draw stronger than the parking circuits to extend. Hence the contradiction between when the doors engage (headlights, no parking) and retreat (no headlights OR parking).
