L
lheindrich
My left front headlight does not come up without me manually assisting it. I did some troubleshooting and all of the hoses are good without any leaks. Unfortunately my holding tank does have a leak so I bypassed the tank and just connected the supply line that went into the tank to the two feeder lines that went to the headlmp relays with a T fitting. Will this break anything until I am able to repair the leaky holding tank? The left headlight comes up and down now but slower than the right headlight could this be a faulty left headlamp relay or the actuator has a leak? I guess I have mor troubleshooting to do. Also it is difficult to get to the leaky supply valve on the holding tank is it possible to use a coffee can holding tank used in later C3's.
