N
nyernga
Heres a brain twister for the brave.
I installed sylvania headlight bulbs tonight and when test driving the car, with the head and foglamps on, the high beam indicator was dimly lit.
came home, put the previous bulbs in and now the headligyts work, the foglamps come on and the high beam indicator is off....all seemed normal. Problem now is when just using the running lights with the fogs, both headlights light up very dimly. I know someone will suggest a bad ground but it didn't happen until I changed to the sylvania bulbs. Wrong bulbs maybe????? These aren't the stock lights with the sealed beam. It has that l_l connector plug
$10.00 to whoever can figure this out.
