T
twe537
The right headlight decided to defey its control and remain up, a short time later it started working again. The problem moved to the left side same thing. Removed the three relays and cleaned the contacts where liquid electrical tape was used and had gumed up both headlight relays. Re-installed had same problem with left headlight, then switched relays to see if problem moved it did not, left headlight still will not close. The gears are working fine since being replaced by the brass gears. Any help would be appreciated.............COULD THIS VEHICLE BE POSSESSED?? thanks!!
