woodpuppy
;help
Here's a link to my original thread;
http://www.corvetteactioncenter.com/forums/showthread.php?p=925055#post925055
This is a related item to my previous post, but still different enough I wanted to start a new thread.
I have a 1986 Coupe, L98, Automatic, with Electronic Climate Control.
When I purchased the Vette a few months ago the hoses to the heater core were disconnected which lead me to believe the heater core was bad.
I finally worked my way down my punchlist to #3 Heater Core Replacement. I came on to CAC and solicited advice in my previous post, purchased the heater core, coolant, thermostat, and all new hoses.
As I stood in the driveway surveying the task at hand I started to wonder if the heater core was actually bad or if the previous owner disconnected it for some unknown reason.
So I decided to drain the cooling system, replace the thermostat and all hoses, remove the homemade bypass contraption followed by a complete flush and refill with a 50/50 mix of coolant and water and 1 bottle of Royal Purple Purple Ice.
On the initial test drive (after idling in the drive for 20 minutes) I wasn't getting any real hot air from any vent, just kind of warm. But after 10 minutes of driving the air from the vents got really hot.
Numerous checks for leaks or a wet floorboard during the refill, test drive, and hour plus idling in the drive provided a good suprise; the heater core wasn't (still isn't) leaking. And now I have heat
Now here's the new problem/challenge I can't get the air to cool back down. No matter which vent (defrost, heater, dash) the air comes out of it is all hot all the time now. I hear the doors opening and closing as I cycle through the various vent settings. When on defrost air only comes out the top of the dash, on heater via the under dash vents, dash vents on that setting, and both dash and under dash when on bi-level.
My ECC display has been tempermental since I purchased the car, but if I push a button what's supposed to happen happens I just don't have a digital display.
So there (here) I am pushing the cool button for the temp setting and it is staying hot.
A check of the A/C components under the hood show the lines and dryer (?big silver cylinder just behind the radiator on the passenger side) are very cold and the A/C compressor is spinning/engaging, but still no cool air coming from the vents.
Prior to putting the heater core "back in line" the AC was working great, blew hard and cold.
I've doubled, tripled, and Doubled Doubled checked all of my hose connections to make sure I have all of the cooling plumbing correct.
I am at a total loss here
Could the "cool" button on the ECC have died and the other buttons still work just fine? That seems to simple and coincidental, but not out of the realm of possibilites I guess.
Coolant temp is running between 190-200 degrees while idling and driving.
All air has been purged from the cooling system.
Coolant is at the proper level.
I disconnected the battery to "wipe" the system clean per se with the same results.
If you need more info please ask away.
Thanks in advance for any assistance, help, advice offered.
Jeff
Jeff
