eoseitz
The previous owner of my 74 corvette hooked up an HEI distributor. He did a hillbilly job of wiring it. He ran a toggle switch and a direct wire to the battery in order to bypass the resistor wire. Does anyone know of a good ACC hook up in the fuse box that is powered on when the key is turned on? I have a new engine wiring harness, but I know it's got the resistor wire for the distributor too. Also, the previous owner moved the alternator to the passenger side of the engine so he could access the power steering resovoire eaiser. Is there an extension cable I can get for this so I don't have to splice into my harness like he did? Underneith my hood is a mess. A nightmare of cut wires and electrical tape. I have the color wiring scematics so that should help.
