HEI in '68
00fxd
B.C. Canada
'65 Convertable
Can anyone tell me if a large cap HEI [no tach drive] will fit in a '68? It looks like it will get pretty close to the washer pump.
Thanks, Frank.
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Thanks, Frank.
Do you have an HEI distributor? How bad do you want to find out? I have an L82 distributor that I need to get out of my garage. Since I moved to TPI... I've had no use for the old vacuum advance OEM distributor.
Vettehead Mikey
Not that far from Ottawa
1973 Coupe
It will fit just fine, but you will lose the functionality of your mechanically driven tach. You're aware that it will make no difference in performance?
fine69
Maryland / D.C.
'69 Convertible Vette; '72 Z28 Camaro Rally Sport
It will fit. Mid America Corvette offers one that also has the mechanical tach drive.
Springfield, MO
1996 LT1 automatic, Polo Green
If you've got a small block, the HEI probably won't clear a stock air filter housing. A big block won't have this problem.
00fxd
B.C. Canada
'65 Convertable
Thanks all, I figured it would fit past the wiper motor/washer pump, Some told him it wouldn't so I thought I'd ask before I wasted my time. I have one to install.
KANE
Moderator
KY
I have one of those too! For sale to a good home!:L
o2bnkc
Carson City, Nv.
2002 M.Y. convertible
Use a pertronix module. You can use your same cap.
00fxd
B.C. Canada
'65 Convertable
If it was my car I would use the HEI tach drive dist. My friend needs to rebuild his points unit and wants to drive it while its out.
