S
studiog
Hi,
I am building a 283 motor for my 1961 Corvette. I have found the correct block casting and date for the car... a 1961 block. I also have a fresh reground 283 crank according to the casting numbers and I even measured the stroke to be sure it wasn't a 327. When I did a pre assembly of the crank in the block I found that the counterweights of the crank don't clear the block. The cast number of he crank 3876768 indicates it was manufactured between 1964-67. Is there such a thing as an early 283 crank and/or block. I thought any 283 crank would fit any 283 block. Thanks in advance for any help that might be provided.
Gary S. :confused
Gary S. :confused
