SPANISHVETTS
- Joined
- Nov 5, 2002
- Messages
- 1,143
- Location
- El puerto de Santa Maria Spain
- Corvette
- before 60,63&82 now 90 383 Stroker & 91 ZR1-Sold
SpanishVettes: I have thought a bit about 3.89. My car is able to hold down the 4.10's, but only just and only in a straight line. Are you saying that 3.89 is quiet where 4.10 is not? It's only a 5% different ratio... so that may be a small enough change to not feel anemic to me. And if it makes all the difference in sound issues... maybe that's the right thing to do.
I have nothing to base this on but gut feelings and 40 years of hot roding + a bit of math. The 5% difference between 4.11:1 and 3.89:1 requires a much more drastic ring to pinion size difference than say the difference between a 3.89:1 and a 3.73:1 would. The 4.11s are close to the limit for the Dyna 44. If you could stick a bigger carrier under the car then the Pinion could be larger, allowing more meshing with the ring gear, which would mean less noise.
Don’t take this as gospel…at best I am a hack taught by a shade tree, and a very opinionated one at that.
Replace the bearings and seals, it is cheap insurance. We never re-use a bearing, even if in only has a few hours on it!You know... if the problem was caused by a new bearing that's defective, having them setup a different case entirely may actually be a good thing. If they just replace my ring and pinion in my current case, I don't think there will be a second rebuild kit installed.
