IndyDave
New member
Hi everyone,
I was searching the forums on the subject of Z06 oil consumption, and some posts were helpful. I do however want to delve into this a bit more.
I am two days away from finalizing a deal on a used 2001 Z06 which has 24,000 total miles on it. The seller indicated that the "low oil" light comes on once between oil changes, and he simply adds a quart and that takes care of it. From the "Spiffy - Lube" sticker on the windshield, it appears that he gets an oil change every 3,000 miles, and has them use Mobil 1.
Do you get the impression this is a car I should shy away from? From looking at old posts in the forums it doesn't sound like an uncommon problem, but it is hard to tell if it is a case of excessive oil consumption.
I do have every intention of taking this car to road course tracks for drivers schools and open lapping time. I am an aggressvie driver on the track, so the car will get "wound up" regularly.
It sounds like the 2nd piston ring swap is done routinely by dealer garages. I read one post that said you would have to have more than 1 quart of oil consumption in 2500 to 3000 miles before GM would take care of it. Does this sound right? My big question is, even if my oil consumption would be over that, and I am the 3rd owner of a Z06 no longer in warranty, will I have to pay for it?
Any input would be greatly appreciated.
Thanks!
Dave Tozer
"IndyDave"
Indianapolis
dave_tozer_cci@lycos.com
Thanks!
Dave Tozer
"IndyDave"
Indianapolis
