misterKTM
OK - my problem has really elevated...what started out as a heavy lug engine miss and a rough idle is now a barely driveable situation. Anything over a slight throttle load will send it into a missing, stumbling coughing fit. It hasn't stranded me yet, but man - it is not happy at all. Major cut out when you give it hardly any gas....
So...What I've done so far...Checked fuel pressure - all looks good there. With a timing light hooked to the coil lead - I can see the miss in the light - so between that and the fuel pressure check - i'm convinced it is ignition. I did replace the knock sensors - as this was the only code I got. Also replaced the coil - as the resistance on the secondary winding was out of spec - and got worse with heat - but niether of those solved the problem. I'm down to either the ECM or the Opti-crap. I have reciepts from the previous owner that the opti-spark was replaced right before I bought the car, and I've only put 10K on it. There is a vent line coming off the bottom of the opti-spark - so I do think it has been replaced - as '93's didn't come with vents, right ?? The vent line just runs up to the valve cover area though - it is not plumbed into a vacuum source. Plus, I suspect the gal I bought it from had the engine pressure washed or steam cleaned as it was very clean when I bought it.
So - thoughts? advice ? suggestions ? Time to tear the opti-spark out or what ?
Thanks,
rob
Thanks,
rob
