I am guessing that is the O2 sensor on the passanger side; and I am also guessing that this would be the one before the catalytic converter. As you may already know there are 2 pairs of O2 sensors (total 4 in the car) on the 96 Vettes - 2 in the driver side and 2 in the passanger side. In each pair one is before the cat and one is after the cat.Magmotor said:That code reads: "Engine O2 Bank 2 Sensor 1 Switching" I would guess that your O2 Sensor on the passenger side has gone south or a bad connection. Hope this helps a little.
