S
Sky65
I just installed a VBP suspension kit with front coils and rear composite spring on the 65. Also replaced the control arm bushings, tie rod ends, ball joints and rebuilt the relay rod.
Problem is when I drive the car forward about 25' and stop both front wheels have obvious positive camber. When i drive the car backwards the 25' both front wheels have obvious negitive camber. It makes no noises like something is shifting, quiet as a mouse. I measured to see if the left wheel was shifting in the wheel well opening and does not apppear to be. Any ideas? This thing is driving me nuts!!!
