Hi All
Well, yesterday was the last show for the season for me and I planned on starting my winter projects this week so early this morning I went to the garage, broke out the tools and got started.
So far everything went fairly smoothly:
took pics of everything I've done syep by step and even did a few drawings to hep myself remember how things were to help me later on during re-assembly.
I got the distrubutor and coil out with no problem
got the carb all disconnected and removed with no problem
than got a bit stuck and need some advice on two things:
1.) Proper way to remove feul filter.
There is a verticle hardline that runs up from the fuel pump to the fuel filter assembly. At the top of the hardline it's threaded with a nut than goes into a 90* fitting that than threads into the fuel filter input.
I'm figure I need to loosen that nut on the verticle hardline to remove the fuel filter but it won't budge. I'm afraid of using too much force as it seemed like the hardline would begin twisting and/or kinking or maybe pull out from the fuel pump.
Any suggestions or directions on the best and safest method to loosen that nut to remove the filter?
2.) How does the oil fill tube come out? I don't see any kind of screw or bolt holding it into the intake but when I grabbed it and tried to pull it up and out thinking it may have just been a friction fit it won't budge.
Plans for the next day or two are to get the intake, valve covers and exhaust manifolds off so I can get them to a fellow forum members home who offered to help me glass bead blast them and the carb will be sent out for a complete and correct rebuild.
Here is a pic of where I'm at so far this morning.
I figure for my very first time doing all this it has been good progress for only about an hours work.
