Help!! Hood Latch Stuck on my '78
F
Frank
Just bought this beauty and the hood opened before she was mine. Now, the passanger side won't unlatch. I called the dealer and he said "Good Luck" I've tried several times to release the latch and it's STUCK! Without taking a sawsall to the corner, any suggestions?
Thanks, Frank
1979toy
Wichita, KS
Red on Red 1979 L-48
Look in the wiper tray area. You will see a rubber plug near the latch. Remove the plug and put a screwdriver through the hole and press down to trip the latch.
Like the dealer said, Good luck. Except I mean it!
80convertible
Asheville, NC
1973 converted to 1980 custom convertible
Also,
Go to corvettefaq.com. I think there is a section on this. Plus its a great info site.
Regards,
Jim
Northern Virginia
71 Conv. (Sold) / 98 Pewter Coupe (Sold)
Check out this thread. It has a link from Mid-America with pics and step by step instructions.
Yoda
Administrator
Amarillo, TX
1981 UL5
Frank,
Here is a previous thread about this and a possible quick OPEN :J for your hood..
Stuck Hood
S
Stryker_78
I have something for you to think about. I have a 78 and the frist time I tried to open the opn(after I bought it) my passenger side hood latch would not release. You won't beleive what it was. My car comes equipped with a nice security feature that prevents the hood from being popped unless it is activated. If you have such a option, then you might find it under the dash below your steering wheel. It should be a little pushbutton switch. Push it in and hold it while at the same time pulling the hood release.
This is just a thought. I hope this will help.
Does anyone else out there have the same kinda security feature? Let me know. Thanks.
Good luck Frank. :w
