kevin-design
Ok, I made the most embarassing mistake of my career yesterday while frantically racing around to auto parts stores in my quest to do my very first transmission swap. I'll cut the misery (the major part of this story) out and tell you the problems. I haven't slept yet so sorry if this is a little fragmented-
Anyway, so the big mistake is that I grabbed the first quart bottles of mobile 'transmission fluid' that I saw at the store. Turns out that it was actually 'Automatic transmission fluid'. So it took about two quarts of fluid before I realized that I was putting ATF in my manual 6 speed.
Now what?
Because I had to move my car by this morning (blocking a bay at work), I did start it and happily, it moved when I wrestled it into gear (very difficult). All I drove was backwards and then forwards into a parking space- maybe 30 seconds of drive time. It still has ATF in the trans. How big of a problem is this and how do I flush/replace the fluid- and with what recommended oil?
Secondly, the clutch pedal goes to the floor now with very little effort. I really don't think its engaging the clutch at all. There is/are no apparent leaks in the cylinder, and all the linkages seem to be in good shape. What's the problem with that?
Thanks for any help!
-kevin
ps. this is a '92 LT1 convertible.
Now what?
-kevin
