alvette
New member
After removing the bearing caps from the center unit, the gears and carrier rolled out of the center section with no resistance. Upon further inspection, I noticed there were not any shims on either side of the carrier. Further inspection leads me to believe the unit had been rebuilt before; RTV on the back of the bearing caps, RTV debris in the unit; not a very well done job.
Now my question, What is the final width of the carrier supposed to be? I looked in my FSM and have not been able to find any information regarding the original width of the carrier + shims. I am not under any illusion GM created these differentials to have zero adjustment requirements. So, where are the shims? I know I will have to adjust backlash and pinion depth, I just would like a reliable starting point.
PS - I have not removed the pinion yet, I need to get a socket which will fit the pinion nut. Can't wait to see what improvements were made here.
Any help is appreciated...
