coves4me
OK, I solved an aftermarket radio issue by installing the resistors and diode and that made the C72 and H72 codes vanish. I jumped the #4 and #12 pins on the connector under the dash and I still get a C42 code in the "A" module, the Derm (airbag) module. This is a non-issue as I could care less about the airbags and whether they work or not. BUT, my brand new OEM cooling fans still run continuously and the Service Engine Soon (SES) light still illuminates continuously with NO other codes showing. I'm puzzled. I've replaced the MAF sensor with a new AC Delco replacement, the ECT sensor has been replaced, the MAP sensor has been replaced, the EGR valve and EGR vacuum solenoid are new, a new AC Delco fuel cap was installed, a new fuel filter was installed, a new fuel pressure regulator was installed, the catalytic convertors have been replaced and the O2 sensors were replaced the Denso types. Now, I've got new AC Delco O2 sensors to install, but there are no codes showing that indicate the Densos are throwing the SES light. Could the Denso O2 sensors be throwing the SES light with no codes? I'm puzzled and could use some help. Thanks in advance.
Mark
Mark
