HELP! No a/c fan/blower
  • Thread starter Thread starter dallas916
D
dallas916
450 miles up the Nevada desert with no HVAC fan...ugh! I pulled all 3 panel fuses to rest and nothing worked. I looked for codes in the fan control window...no codes. The manual says there's an UNDERHOOD fuse to protect the fan (blower) motor.
WHERE is it???????????
How about the blower relay? Is it inside or outside the heater core box? The manual shows it attached to the side of the box...but it's not there.
It turned out to be the blower motor/fan itself. I picked up a replacement at Kragen's along with a multimeter and did the swap last night. Works like it hasn't in 3 years. I should have done this the first time it quit blowing or seemed to slow down.
Thank you Kragen's for being open on Easter Sunday evening!
