newtwoC-4
- Joined
- Aug 4, 2016
- Messages
- 13
- Location
- Skidmore,Texas
- Corvette
- 1993 Forrest Green Coupe, 1982 Red Coupe
Hey guys/gals, I've got a 93 standard model. I'm getting ready to tear into the dash to replace the stereo system, but before I do I have a few issues that maybe in the dash area (only want to tear into it once).
First thing is I have a SYS display that flashes 3 times and goes out for 15 seconds then repeats. If the door is open it doesn't do it, as soon as you close the door it does. Any tips what it is and maybe what's causing the problem?
Second thing is the Display on the LCD speedo is DIM. Difficult to see during the daylight hours and not very bright at night. The cluster lights are fine and are adjustable.
Third thing is the Courtesy lights (at one time would fade out when you closed the doors) now they won't shut off, unless I pull the fuse.
Any help or direction to correcting these issues would greatly be appreciated!
Thanks to all in advance!
Bobby
Bobby
As you have already found, our community is full of very helpful people. I hope you are able to complete the repair in of your 93.
