R
rpounds
I feel like an idiot asking this question. But, I'm yanking my well worn hair out here.
Today I helped a neighbor tear down his 350 for a cam change. In the past, I have made it a habit to set the engine to TDC on #1 before yanking the distributor. It makes it easier to get the distributor back in the right orientation when placing it back in the engine.
Anyhow, with the rotor pointing at #1, and the #1 piston at TDC, the cam is 180 degrees out!! Again, this is from in a running engine!!
Is it possible for an engine to run with the cam 180 degrees out??!! Or am I just being stupid and overlooking something?
