84VetteXram
New member
I am brand new to the forum. Have worked on cars since I was a kid but nothing really big. Basically enough knowledge to be dangerous. My current issue(s) started out and continues to be a high idle issue, 1100-1900.
A few weeks back it threw a code 22. I replaced the TPS, code went away but the idle issue continued. I replaced the IAC's, coolant temp sensor and the high idle continues. It seems to be sporadic, once warmed up and driven a bit, it will settle down to around 1000, which actually seems normal, but, I know it is not. So, anyway the other day the code 22 came back. I went through the FSM diagnostics and everything checks out until diagnosing circuit 417.
I will admit I am an idiot on electrical issues so please bear with me. When I disconnect the white ECM connector and check for open or short to ground, I get open (DVM set to ohms). But, I am not sure what that means? It says if circuit 417 is OK, then it is faulty ECM connector pin 5 or ECM. Does open mean it is ok?
I have ordered an ALDL USB connector to get more data.
In the meantime I decided to clean up the tangle of wires around the distributor. The car has been modified with an Xram and some other ignition modifications (I think). I decided I want to get rid of all the Accel add ons since I use this vehicle on the road and have no interest in tracks.
In the distributor there is an Accel Performance Control Module (35363), there is also an Accel 300+ Racing Ignition. I was thinking to get rid of the Racing Ignition anyway, I guess the Control Module would need to be replaced so I would just leave it in there.
My question on the Accel 300+ is. Can I simply take that out? If I can how would I connect the wires? I do have the FSM and will look there as I wait for the ALDL to arrive to troubleshoot the high idle issue.
In the meantime, thanks for any advice. I will post updates and hope to add some value back in the future.
