mick_s3
Help: Rear axle grease on the inside LR (Driver side) rim and calipers.
I took the LR tire off to attempt to change the fuel filter and found a big grease spot on the inside of the rim and found very thin lines of grease flung all over the wheel well. There were thin strands of grease on the shock tower and caliper.
I assume this was flung out of the boot on the axle? What am I looking at to address this? Is it possible to have them replace the boot or does the axle have to be replaced?
Should I do both sides while I am at it? I didn't notice any on the passenger side......
Any insight would be greatly appreciated.
Thanks!
Thanks!
