bpdfs
I looked in the service manual, but couldnt find anything about removing it. I need to get it worked on and wanted to know the best way to remove it???? Thanks
If you need to remove the radio, go to Dr. Don's site and he has a schematic on his site that shows how to remove it. To remove it, you have to remove the shifter trim plate, then the trim plates around the radio and vents. Remove the screws holding the radio in, and unhook the power cables from the back. Be careful with the screws, because if you drop them, you will have a devil of time retrieving them. The FSM should describe how to remove the trim pieces, etc. My 94 FSM described how to remove the pieces. Just take your time and don't force anything. You may have to remove the console lid to get to one screw in the shifter trim piece. You may want to make notes if you plan to send the radio out for repair so that you can reinstall it correctly. It is not hard to do, just takes some time.
Barrett
