S
sothpaw
In replacing my dead storage battery with a new AC delco unit,
the first instruction is "remove the negative cable from the battery..."
The bolt head is stripped! I have tried to budge it, with no
success. It seems like it was either very over-torqued or is
corroded in place. My efforts have only made the head worse.
It is now almost completely round instead of 6 sided hex head.
What can I do with this? Is there a way I can remove the
positive terminal, get some room to work, and remove the
whole negative battery cable?
Or do I have to drill into the bolt somehow and remove it?
It seems like this won't work, as the original head wan't strong
enough to overcome the torque either....
Andy
Andy
til you are :dance :cool
