Help The New Guy Here! Loss Of Power!!
  • Thread starter Thread starter psychomatica
hmm.
i have my injectors off righ tnow currently
im goign to check that out, befor ei stick them back on
i took it off to chrome my fuel rail
what does intermented mean???
i dont' understand this,, does it mean,, no eletricity getting ot it? or the its not ohming high enough, i mean
Re: what does intermented mean???
It means that the problem comes and goes, and or it only works right once in a while. These are the worse kind of problems, because until there is a total failure, it is hard to determine what the problem actually is. Kind of hit or miss.
man
that,, really sounds like a problem i might be having,,
my spark plug wires are really crappy already, and my timing isn't set right
im going to do those two things first,,
then im going to test the pressure of my fuel,,, and before that,, tomrorw im going to clean out my airflow control thing
WELL....
I actually first thought it was the CATS but i had them pressure tested(as in the post) and they were good to go,..as wel as i have now changed the O2 sensor and that did SQUAT...sooo..and also the other sensor i am speaking of are actually heat sensor
So now i am changing the injectors!!
:hb
IAC
So, im able to take of fmy IAC and just clean it out right and stick it back in, good as new?
