nelsonvette
I have a 95 coupe with auto climate control. The problem is when set on auto and the temp set to 60 or any temp as far as that goes , I get hot air blowing in only for a few seconds then it goes back to cold and sometimes it is just warm air but it only last a few seconds then goes back to cold. I changed out the control module, the one inside the car with all the buttons and it still does the same thing. Had the A/C checked and it checked out fine. Last night I was going about 70MPH through a long right turn and the auto light started flashing and I got steady hot air.First and only time it has done that. Switched it to off then back to auto and it worked again with the intermittent warm spells. I ran the diagnostic by pressing the up down arrows and it came back 00 no faults. Any ideas would be helpful.
