L
LAC
I am an owner of an '01 Z06. I am getting a high pitched whine from the front of the motor at idle. Sounds like a bearing. The local dealer has replaced the belts, changed the intake, and air conditioning idler. The noise is still there. The tech has removed all the belts and the noise was still audible. I was told by the service writer that he has other Corvettes with the same problem... so far the service team does not have a clue. Most noticeable when engine is hot and ambient air tempature is in the 90's. Some have described this noise as an air or vacumn leak, but no one can fix the problem.
Anyone have a suggestion????
