- Joined
- Oct 7, 2007
- Messages
- 720
- Location
- Amherst, NY
- Corvette
- 1996 Torch Red Coupe (Prior 1988 and 1989)
A new IAC should be at the proper length, if it is not, then you adjust it as per provided instructions. No need to set it perfectly. The IAC reset procedures calibrates the IAC. You just don't want the pintle to score the TB when installing. It should be torqued down to spec with the provided thread sealant.
I would never reuse a IAC that the pintle what removed. The IAC pintle was meant to move internally, not externally. You DO NOT clean an IAC pintle by shooting it out.
