- Thread starter
- #61
joshwilson3
Doesn't surprise me. I found diiferent procedures when investigating this as well. When I documented all of the steps provided earlier for throttle body adjustements, I stayed as true as possible to the GM FSM instructions. Specific to IAC reset, no changes required.
Depress accelerator pedal slightly
Start and run engine for 5 seconds
Turn ignition key off for 10 seconds
When you depress the pedal sligthly, the engine draws in extra air, more than what is required by the ECM to reach targeted (programmed) RPM setting. So the ECM extends the IAC pintle, trying to reduce IAC air flow. Since air flow across the plates is more than the ECM can manage, the ECM signals the IAC into full extension (closure). The ECM and IAC are now insync with each other. On restart, The ECM uses several variables and prom settings to signal initial IAC position. Post procedure a scanner should be used to verify the IAC counts.
Ok, thanks. I'll stick to the FSM method.
