boomdriver
I got the injectors in. And it looks like I'm now running lean. My BLM hangs around 145. Sometimes goes to 148.
With the key "on", my pressure was 40-41 psi and held for 20 minutes or so before falling. Which looks to be in spec of 40.5-47 psi.
With it idling, it is 34 psi. Which looks to be in spec of the 34-39 psi. I did notice when I blipped the throttle that the fuel pressure would dip some.
I'll probably redo the pressure tests. And I'll probably drive around with the gauge hooked up laying on the windshield to see what that does. There isn't any fuel coming out of the FPR.
It looks like with the 24# Accel injectors, the BLM's hung closer to 128. With the Bosch III's it mostly is around 145 all the time.
You cannot accept ANY live data until the ECM has been in normal run for at least 30 minutes under normal driving conditions with a bit of throttle, some extended cruise time and also some idle as in stop n go. The ECM will "float" around until it builds a memory again of run events.
The fuel sounds right. It should dip as the revs go up them recover. Thats exactly what it should do. The sudden demand for fuel lowers pressure for an instant, then the pump (GPM ability) makes up that lost amount and stabilizes.
Drive it for 30 min or more, then it should start to find its normal programming again. C4 ECMs DO have a memory that gets erased when the battery gets disconnected. That has to be re-learned before it will run right.
Sounds like it'll be fine. Remember, it thinks its lean now because it got use to rich. After it runs and builds memory, it'll be normal.
Good Job !
