- Moderator
- #21
Toms007
Moderator
I, too, am no tire expert, but Vettehead Mikey is right on with his post. Tire manufacturers make the tires for a variety of cars. The weights of those cars can vary dramatically. Depending on the load rating, they can have two tires the same size that have different pressure ratings depending on the maximum load the tire can handle.
With my pickup, for instance when I run with it empty I run the GM recommended tire pressures. Once I load it down or when I pull a trailer I add air to help carry the added load...maybe clear up to the max pressure listed on the tire, maybe something less. If I leave the higher pressure in the tire once it is unloaded, the ride becomes very uncomfortable. The auto manufacturers have done all the engineering to find what is the best pressure for the cars at a normal operating condition. I believe that the owners manuals even try to discuss these differences.
As to your reference to the bike, the only thing I can say is I don't think that the bike manufacturers do quite the same engineering for bikes as they do for autos. But, for your information, I follow the same rules. On our bikes (Schwinn) I usually have the maximum recommended pressure for the tire on mine, 50 psi (I weigh around 215) on my wife's identical bike (except the frame size is smaller) I run about 40psi (she weighs considerably less than I
I hope that this explanation clears up some of your questions.
