Buckskin7T7V
Me Again. I running a Holly 4165 spread-bore on my 77. After my smog inspection this pass week, the tech indicated to me, that the carb was running too lean. This carb has revers idle jet needles. This means, when you turn the idle needles in, (clockwise) the mixture richens. He had to turn these needles all the way in and it is still too lean. I was hoping if anyone out there knows, how to richen the "MIXTURE" adjustment on this type of carb. On a standard carb you would reduce the air bleed size. I do not what to do what woud seems the logical thing and drill these out and later find out, that an non-destructive method would have been better. I know that float adjustment is very important and as soon as possible, I will be checking that.
