IMO the AFR have two advantages over the GM Vortec, that being the cool down factor and ability to run the higher compression ratio and stay out of detonation. However, the vortec heads in the tests listed previously are the old ones with the 165 runners, which are smaller then the afr and says something about velocity of the charge. Now they have Vortecs with larger ports, bigger valves and still cheaper than AFR. AFR only other advantage is the weight savings, and for me I would rather carry an extra 30 pounds and have and extra 30 ponies with it for a lot less money. Like you are doing, I asked a lot of questions and did a ton of research 4 or 5 years ago when I needed to redo my engine. I guess, if I was to work with a 27K motor, to me it would be worth the money to freshen up the bottom end and at least put in some better than cast pistons for power over 350 HP.This thing of which is better is all just preferences. I built what I wanted, you will build what you want. My budget was different than yours and so was my starting point. AS long as you put your hot motor in a vette and smoke some pony cars, then you have done the right thing. Smoke them stangs.
